HP Envy 15-u001dx Wireless Network Card Replacement
Выберете то, что вам нужно
  1. HP Envy 15-u001dx Wireless Network Card Replacement, HP Envy 15-u001dx Disassembly: шаг 1, изображение 1 из 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Wireless Network Card Replacement: шаг 2, изображение 1 из 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Wireless Network Card Replacement: шаг 3, изображение 1 из 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Wireless Network Card Replacement: шаг 4, изображение 1 из 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Wireless Network Card Replacement: шаг 5, изображение 1 из 2 HP Envy 15-u001dx Wireless Network Card Replacement: шаг 5, изображение 2 из 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Wireless Network Card Replacement, Wireless Network Card: шаг 6, изображение 1 из 1
    • Remove the Phillips #0 4.5 mm screw from the wireless network card located in the back, right side of the interior.
  7. HP Envy 15-u001dx Wireless Network Card Replacement: шаг 7, изображение 1 из 1
    • Use the spudger to remove the antenna connector attached to the black wire labeled "1".
  8. HP Envy 15-u001dx Wireless Network Card Replacement: шаг 8, изображение 1 из 1
    • Detach the antenna connector for the white wire labeled "2".
  9. HP Envy 15-u001dx Wireless Network Card Replacement: шаг 9, изображение 1 из 1
    • Gently remove the card from its slot by pulling.
Заключение
Еще один человек закончил это руководство.
Dakota Presley
Участник с: 10/05/16
885 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 9-4, Lacy Fall 2016 Участник USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 583
