Выберете то, что вам нужно
Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
Remove the two cover tabs towards center of the bottom as there are screws underneath them.
Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
Separate the top cover by using a spudger to go around the sides freeing the inside latches.
Remove the Phillips #0 4.5 mm screw from the wireless network card located in the back, right side of the interior.
Use the spudger to remove the antenna connector attached to the black wire labeled "1".
Еще один человек закончил это руководство.
