Введение
Follow this guide if you want to replace the motherboard of your HP Envy 17-3070NR. The motherboard connects all parts of the PC together and it is a most complex part of the computer. Unfortunately, with great complexity comes great room for failure. Should any of the components on the motherboard fail, whole motherboard needs to be replaced to fix the issue.
Выберете то, что вам нужно
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the six 3.7mm Phillips screws.
Slide the back cover until it clicks, then lift it straight off.
Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
Remove the hard drive by lifting it out of its cavity.
Unplug the hard drive cable that connects it to the main assembly.
Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
Remove the battery by pulling it straight out away from the computer.
Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
Remove the subwoofer by pulling straight up from the main assembly.
Press down on both tabs on either side of the top RAM stick.
The RAM will slightly pop out and you will be able to slide it out of it's cavity.
Repeat the same process for the second stick of RAM if needed.
Unscrew 4.5mm Phillips screw.
Unplug both antenna connectors by carefully pulling them upwards.
Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right.
Remove the seventeen 6.6mm Phillips screws.
Remove the three 3.6 mm Phillips screws.
Remove the eleven 3.2mm Phillips screws
Flip the laptop over.
Use a Plastic Opening tool to carefully pry all around the top cover up off of the remaining assembly.
Gently pull the white connector shown in the picture towards you to disconnect it from the system board.
Gently pull the black connector towards you to disconnect the top cover from the main assembly.
Once both connectors are disconnected, lift the top cover off of the main assembly.
Remove the two 4.5mm Phillips screws from the system board
Disconnect three cables by lifting a white clamp with a Flathead screwdriver and pulling on the blue tab.
Disconnect three cables by pulling upward on black or blue tabs connected to them.
Disconnect cable by using a Flathead screwdriver to gently pry it off the black connector towards you.
Flip the system board over.
Unplug the first fan assembly cable by carefully pulling it upwards.
Remove the three 4.5mm Phillips screws on the fan assembly.
Loosen the seven captive Phillips screws in the ascending numerical order (1-7). Numbers are printed next to each screw on the housing.
Remove the fan assembly from the system board by lifting it straight up.
Unlock CPU by turning the locking screw 180 degrees counterclockwise using Flathead screwdriver. You will hear a slight click when CPU is fully unlocked.
Carefully lift CPU upwards by holding it from both sides.
5 участников успешно повторили данное руководство.
