Введение
The scanner piece is a part of the printer that scans over a paper. It may become misaligned or damaged over time. This guide will help a user replace the scanning piece.
Выберете то, что вам нужно
Locate the cover hinge on the right side of the printer.
Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
Remove the five 11.5 mm screws located at the bottom of the scanner.
The top of the scanner will now easily pull off.
Lift the scanning piece and detach the ribbon cable by gently pulling on it.
Еще один человек закончил это руководство.
