Введение
In order to replace a broken CD Drive, this guide will show you how to do just that!
Выберете то, что вам нужно
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
Reorient the device with the front pointing away from you.
Next, remove the SATA interface cable. It is directly next to the power cable on the CD drive.
Now pull up and swing the mounting lever in. The lever closest to the front mounts the top drive slot, and the lever farther away mounts the bottom one.
Now stand your desktop up and remove the 3 clips on the right side of the front panel.
Then pull the front panel off, pulling from the side that the clips are on.
