Введение
Has your battery seemingly died far earlier than expected in your HP Envy 15 x360 laptop? This guide will show you how to fix a common cause of a dead battery.
Выберете то, что вам нужно
Plug in your computer to charge and take a look at the light coming from near the charging port.
Flip the laptop over on its back and remove the two depressed stickers in the middle to reveal the two central 6.0 mm Phillips-head screws.
WARNING: There are two more screws to be removed! They are located under the rubber feet in back, by the hinges. Peel off the feet to expose the screws, and then unscrew them.
I learned about them from this article, after spending 10 minutes trying to get the back corner free.
Once all of the screws have come out, flip the laptop over and open the lid so that the keyboard is face up.
Pop the keyboard from the sides and carefully lift it off of the parts underneath.
Carefully lay the keyboard section against the open screen of your laptop without unplugging anything.
Check the inside of your laptop to make sure there are no glaringly obvious problems (insects, missing parts, scorched parts).
Locate the battery and the three 4.0 mm Phillips-head screws that hold it in place.
Unscrew these three screws and use the tab attached to the battery to remove it safely from the laptop.
Once the battery is safely removed, plug the charging cord into the charging port on the side and plug the other end into the wall.
If the light is on after plugging it in, you have just confirmed that something is wrong with the battery, which means you're on the right track!
Unplug the charging cable.
Place the battery back where it was previously and find where it was plugged in.
Plug the cable on the battery back into the port on the motherboard and make sure it is secured.
Run the earlier test from Step 7 that you performed on the laptop with the battery inside.
If the light comes on and doesn't blink, you have fixed the problem! Congratulations!
If the light still blinks, you may have to purchase a new battery for your laptop.
20 участников успешно повторили данное руководство.
9 Комментариев
can you tell me the name of the battery ?
Worked like a gem. Now my battery is even charging. There must be a loose connection between the battery and mother board. Double thumbs up to you!
This worked like a charm for me. Thank you for posting!! followed directions exactly, so easy to follow. The only trouble I had was getting the keyboard detached. It was really stuck on there, but I eventually got it. Battery is charging as we speak.
does the battery need to charge before I can use it. I tried to turn it on right after and it won’t.
I did all of this and replaced the battery no problem. The charging light is a solid white, I charged over night but my power button will not work, after I press it, it will flash once white then nothing! It used to turn on before I replaced the battery, did I do something wrong?
The light's steady, but the computer tells me when it restarts (doing a bunch of upgrades) that the battery is well, toast. Just another sign you might want to look for. New battery on the way, and this guide is bookmarked for when it comes in! Thanks!
