Введение
This guide is to help you replace your fan on the HP Envy Sleekbook m6-k010dx.
  1. Remove the twelve 9 mm Phillips #00 screws.
    • Remove the twelve 9 mm Phillips #00 screws.
  2. Use the plastic opening tool and your hands to remove the bottom cover. Use the plastic opening tool and your hands to remove the bottom cover.
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. Disconnect the battery power cable from the motherboard.
    • Disconnect the battery power cable from the motherboard.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  5. Remove the six 6 mm Phillips #00 screws from the battery.
    • Remove the six 6 mm Phillips #00 screws from the battery.
  6. Lift the battery out of the laptop. Lift the battery out of the laptop.
    • Lift the battery out of the laptop.
  7. Remove two 3mm Phillips #00 screws from the fan.
    • Remove two 3mm Phillips #00 screws from the fan.
  8. Disconnect the fan cable by pulling it out of the motherboard socket. Disconnect the fan cable by pulling it out of the motherboard socket.
    • Disconnect the fan cable by pulling it out of the motherboard socket.
  9. Lift the fan upwards to remove it from the computer.
    • Lift the fan upwards to remove it from the computer.
Заключение
Ana Novo
Участник с: 14.02.2018
305 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S1-G4, Nance Spring 2018 Member of USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 13
За всё время: 196
