Введение
If your computer turns on but nothing is displayed on the LCD, it might be time to replace it. This guide will walk you through each step.
Выберете то, что вам нужно
Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
Use the plastic opening tool to remove the LCD screen from its housing.
Lay the LCD screen flat on the keyboard.
Disconnect the cable which connects the LCD to the motherboard.
Pul the LCD screen out.
2 участников успешно повторили данное руководство.
