Введение
You may need to replace the wireless adapter if your computer can't connect to any wireless network. Be sure that you do not break the antenna connector wires.
Выберете то, что вам нужно
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
4 участников успешно повторили данное руководство.
Один комментарий
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
”https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
