Выберете то, что вам нужно
Place the computer on its top on a flat surface with the hinges facing away from you.
Slide the battery release latch to the left which is located on the right-hand side of the battery.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
Slide the service cover toward the front of the laptop.
Lift the service cover to remove it from the laptop.
Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
Press the tab with a metal spudger that is located next to the screw to release the optical drive.
Place the laptop on it’s top
Remove the two screws that secure the keyboard to the laptop.
Stand the laptop on it’s left side with it’s top open.
Locate the circular opening in the optical drive slot.
Using a plastic opener, press on the keyboard through this opening until it lifts the keyboard away.
Place the laptop on it’s back with the front facing you.
Using a plastic opener, lift the back of the keyboard towards you releasing it from the lip that holds it.
2 участников успешно повторили данное руководство.
