Выберете то, что вам нужно
Place the computer on its top on a flat surface with the hinges facing away from you.
Slide the battery release latch to the left which is located on the right-hand side of the battery.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
Slide the service cover toward the front of the laptop.
Lift the service cover to remove it from the laptop.
Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
Press the tab with a metal spudger that is located next to the screw to release the optical drive.
Еще один человек закончил это руководство.
