Введение
CPU Cooling Fan Part Number
686901-001 DC28000BFS0
The CPU Cooling Fan allows for continuous cooling of the CPU also known as the brain of a computer inside a laptop to not overheat and burn the user.
This CPU Cooling Fan can be prone to issues of overheating due to clogging or a faulty fan. If you believe the fan is not faulty and only needs cleaning, you can remove the fan and cleanse it with a computer duster.
This guide will go step-by-step on how to remove a clogged or faulty cooling fan.
Check out the Troubleshooting guide for other issues that could be related to the fan.
CAUTION: Placing the computer on a cloth surface such as your lap, a bed, or a couch cushion, can restrict or completely block the airflow. Prolonged air restriction causes overheating and potential damage.
CAUTION: DO NOT continue to use the computer when a fan is not working correctly. Overtime, exposure to consistently high temperatures can damage other important internal components.
Выберете то, что вам нужно
Pull the slide release tab to the left to free the battery.
Once the slide release is all the way over, a red icon should be visible.
Move the battery slide release latch to the side while pulling the service cover forward.
Pull the service cover straight up and out to remove.
Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
Disconnect the cable from the side of the hard drive and move to the side.
Remove the hard drive.
Make the device stand onto its left side with the device open.
Turn the laptop and look into the empty battery slot for two release holes.
Insert a metal spudger into the release holes and apply pressure to the back of the keyboard until it comes loose of the laptop.
Gently lift the keyboard away from the laptop.
Lift up the cable holder and remove the cable connection from the base of the laptop.
Lift up the locking tab of the ZIF connector and remove the keyboard backlight cable.
Remove the 13 screws on the bottom of the laptop that secure the top cover using a Phillips #1 screwdriver.
Disconnect Power button board cable using a pair tweezers.
Disconnect Touch Pad button board cable using a pair tweezers.
Disconnect Fingerprint reader board cable using a pair tweezers.
Disconnect Right speaker cable using a pair tweezers.
Remove the 4 screws using a Phillips #1 screwdriver.
Apply force to the base of the cover to pop if off from the laptop base.
Remove the two screws holding the cooling fan down with a Phillips #1 screwdriver.
Disconnect the cooling fan cable using a pair tweezers.
Gently lift the cooling fan.
