Введение
DVD RW Double-Layer with SuperMulti drive. Part Number 686916-001
Also known as a DVD player, the optical drive allows the user to play DVD’s or CD’s. This Optical drive also allows the user to create/burn new DVD’s and CD’s.
The Optical Drive can suffer hardware issues which might prevent it from reading DVD’s. You can run a HP PC Hardware Diagnostics test at Support.hp.com. If the diagnostic test is unable to find the problem, the Optical Drive itself could be faulty.
This guide will explain how to remove the Optical Drive for replacement.
Check out the Troubleshooting guide for other issues that could be related to the optical drive.
Выберете то, что вам нужно
Pull the slide release tab to the left to free the battery.
Once the slide release is all the way over, a red icon should be visible.
Move the battery slide release latch to the side while pulling the service cover forward.
Pull the service cover straight up and out to remove.
Use a Phillips #1 screwdriver to remove the single screw holding the optical drive
Use a spudger to apply pressure to the tab, while simultaneously pulling out the optical drive.
