HP Envy m6-k015dx Touchpad Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
    • Shut down the computer
    • Remove all external devices
    • Unplug the AC adapter
    • Close the computer
    • Turn it upside down
    • Remove the 12 screws from the bottom.
    • Gently remove the service cover
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws that hold the battery.
    • Gently lift the battery out of the computer.
  2. Careful: steps 7-9 are sourced from a guide that's marked as in-progress.
    • Remove the fan cable
    • Remove the 2 screws around the fan
    • Lift the fan up
    • Unscrew the 3 screws that hold the card reader board to the system
    • Raise the card reader board from the system
    • Remove the four screws that pin down the hard drive
    • Disconnect the harddrive from its connector
    • Remove the harddrive
    • Only complete this step if your computer model has a solid state drive
    • Remove the two screws at the top of the solid state drive
    • Remove the solid state drive
    • Remove the thirteen screws around the keyboard bracket
    • Gently remove the keyboard bracket from its top
    • Remove the 4 screws on the touchpad's board
    • Gently lift the touchpad board from the side that the screws were on
    • Remove the touchpad board
Заключение
Chuka
Участник с: 02/09/20
621 Репутация
Автор 5 руководств
Команда
University of North Texas, Team S3-G3, Thomas Spring 2020 Участник University of North Texas, Team S3-G3, Thomas Spring 2020
UNT-THOMAS-S20S3G3
2 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 60
