Выберете то, что вам нужно
Шаг 1 Battery
Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
Shut down the computer
Remove all external devices
Unplug the AC adapter
Remove the fan cable
Unscrew the 3 screws that hold the card reader board to the system
Raise the card reader board from the system
Remove the four screws that pin down the hard drive
Disconnect the harddrive from its connector
Remove the harddrive
Only complete this step if your computer model has a solid state drive
Remove the two screws at the top of the solid state drive
Remove the solid state drive
Remove the thirteen screws around the keyboard bracket
Gently remove the keyboard bracket from its top
Remove the 4 screws on the touchpad's board
Gently lift the touchpad board from the side that the screws were on
Remove the touchpad board
