HP Envy m6-k022dx Heatsink Replacement
Выберете то, что вам нужно
  1. HP Envy m6-k022dx Heatsink Replacement, Lower Case: шаг 1, изображение 1 из 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx Heatsink Replacement: шаг 2, изображение 1 из 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx Heatsink Replacement: шаг 3, изображение 1 из 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx Heatsink Replacement: шаг 4, изображение 1 из 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx Heatsink Replacement, CPU Fan: шаг 5, изображение 1 из 1
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx Heatsink Replacement: шаг 6, изображение 1 из 1
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx Heatsink Replacement: шаг 7, изображение 1 из 1
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx Heatsink Replacement: шаг 8, изображение 1 из 1
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
  9. HP Envy m6-k022dx Heatsink Replacement, Heatsink: шаг 9, изображение 1 из 1
    • Prepare to remove the heatsink by removing the four screws that connect it to the motherboard.
    • Make sure you have a Philips 00 size screwdriver to remove the screws.
  10. HP Envy m6-k022dx Heatsink Replacement: шаг 10, изображение 1 из 1
    • Unscrew all four of the screws connecting the heat sink to the CPU.
  11. HP Envy m6-k022dx Heatsink Replacement: шаг 11, изображение 1 из 1
    • Lift up the heat sink by the strip of metal connecting it to the exhaust vent, and pull it away from the motherboard.
Заключение
Еще один человек закончил это руководство.
Kareem Rigaud
Участник с: 03/02/17
403 Репутация
Автор 3 руководств
Команда
USF Tampa, Team S13-G6, Cagle Spring 2017 Участник USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 611
