Введение
These instructions will guide you through the process to remove and replace the motherboard on the HP Envy x2 13-j002dx (Model #J9M64UA). In step 1 of this guide, you will remove the tablet’s outer shell to access the motherboard. The rest of guide shows you how to remove and replace the motherboard.
Выберете то, что вам нужно
Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
Use a pair of tweezers to remove the screw covers on the bottom of the device.
Use a Phillips #0 screwdriver to remove the two 4mm screws.
Use an opening pick to remove the plastic cover above the back stand.
Pry the cover off.
Use a Phillips #0 screwdriver to remove the four 4 mm screws.
Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
Carefully pull up on the battery connector from the speaker.
Use a pair of tweezers and remove the taped down wire for the speaker.
Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
Using a Phillips #0 screwdriver, remove the three 3.8 mm screws along the edge of the motherboard.
Disconnect the cable connectors from the motherboard. This can be done with either tweezers or with your fingers.
Using the Phillips #0 screwdriver, remove the 3.2mm screws within the copper rings in the circuit board.
Using the Phillips #0 screwdriver, remove the 2.5mm and 4.25mm black screws on the motherboard.
Once the screws and cables are disconnected and removed, remove the motherboard from the frame.
Еще один человек закончил это руководство.
