Введение
This guide will show you how to replace the motherboard on your HP Envy laptop. There are two main reason for doing this, you can upgrade your board, or fix a bad one. Without further ado, let us begin.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
Pull the battery from the connecting port and lift to remove it from the laptop.
Use a Phillips #1 screwdriver to remove the seven 4 mm screws securing the fan.
Detach the fan cable from the mother board.
Use a Phillips #1 screwdriver to remove the ten 4 mm screws securing the motherboard.
Pull the four cables directly out of their ports.
Flip up the lock-bar on the two ZIF connectors, then gently pull the two ribbon cables directly out of their ports.
