HP Envy x360 15-u473cl Battery Replacement
Выберете то, что вам нужно
  1. HP Envy x360 15-u473cl Battery Replacement, Battery: шаг 1, изображение 1 из 2 HP Envy x360 15-u473cl Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Battery Replacement: шаг 3, изображение 1 из 2 HP Envy x360 15-u473cl Battery Replacement: шаг 3, изображение 2 из 2
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Battery Replacement: шаг 4, изображение 1 из 1
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Battery Replacement: шаг 6, изображение 1 из 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Battery Replacement: шаг 7, изображение 1 из 1
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
Заключение
Еще один человек закончил это руководство.
Maximillian McDonald
Участник с: 01/13/18
784 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team S1-G2, Ramos Winter 2018 Участник Eastern Washington University, Team S1-G2, Ramos Winter 2018
EWU-RAMOS-W18S1G2
5 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 2,073
