Введение
The battery can stop holding a charge or die completely. This guide will show how to remove the battery inside the device.
Выберете то, что вам нужно
Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
Turn the device right side up and open the lid.
Insert the plastic opening tool in between the keyboard plate and the base of laptop.
Run the tool along seem, prying up as you go.
Separate the keyboard plate from the base, lifting from the front.
There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
Remove the keyboard plate from the device.
Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
Disconnect the battery from the motherboard.
There may be tamper-proof tape holding the battery in place. Remove the tape if present.
Remove the battery from the device.
Еще один человек закончил это руководство.
