Введение
A failing Wi-Fi Card can lead to internet connection issues. If you’re struggling to connect to the internet, the Wi-Fi card in your device may need to be replaced. This guide will show how to replace the Wi-Fi Card in your device.
Выберете то, что вам нужно
Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
Turn the device right side up and open the lid.
Insert the plastic opening tool in between the keyboard plate and the base of laptop.
Run the tool along seem, prying up as you go.
Separate the keyboard plate from the base, lifting from the front.
There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
Remove the keyboard plate from the device.
Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
Disconnect the battery from the motherboard.
There may be tamper-proof tape holding the battery in place. Remove the tape if present.
Remove the battery from the device.
Disconnect the wireless card by pulling away from the black connector using the spudger.
Push up on the two wires to release the connectors and remove the Wi-Fi card from the device.
