Введение
The cooling fan is a key component of a laptop. This component keeps the computer cool while operating. If the fan fails, the computer may overheat and damage components in the computer. This guide will show in-depth steps on how to safely remove a cooling fan from an HP Envy x360.
Выберете то, что вам нужно
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
To remove the back cover, use the black spudger to lift up on the edges of the cover.
Use a suction cup to assist in lifting the back cover
Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
Lift and pull the front of the battery up and out (away from the connector) to remove.
Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
2 участников успешно повторили данное руководство.
Один комментарий
I'm considering attempting this repair. I am curious as to why the instructions direct me to remove the battery before removing the fan. From the pictures shown above, it does not appear that battery is mechanically blocking the removal of the fan. Is the purpose of this step to remove a phisical impedance, or is the reason to remove power from the he device?
