Введение
This Guide will demonstrate how to replace the Wi-Fi card in an HP Envy x360 15m-cn0011dx laptop.
Make sure your device is fully powered of before attempting this guide.
Выберете то, что вам нужно
Remove the six 5.6 mm screws from the back cover using a Phillips #00 screwdriver.
Remove the single 4.3 mm screw in the bottom middle section of the back cover using a T5 Torx screwdriver.
Remove the single 2.3 mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
