Введение
If your HP Envy x360 m Convertible 15m-cn0012dx is frequently overheating, use this guide to replace the fan.
A faulty fan does not effectively cool your computer.
Before starting, make sure all external connections are unplugged and the computer is turned off.
Выберете то, что вам нужно
Set the laptop face down.
Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
Pry open the back cover using the iFixit Opening Tool.
While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
Once all the corners are slightly lifted, carefully pop off the back cover.
Remove the two 4mm screws from the fan using a Phillips #0 screwdriver.
Peel the tape off of the multicolor cable bundle connecting the fan to the motherboard.
Use the iFixit opening tool to disconnect the connector.
Peel back the tape from the heatsink.
Use the Phillips #0 screwdriver to remove the four captive screws from the heatsink.
Unlatch the black cable from the plastic guides on the fan.
Lift the fan from the laptop case.
2 участников успешно повторили данное руководство.
