Введение
If your HP Envy x360 m Convertible (Model 15m-cn0012dx) isn’t holding a charge or won’t charge, use this guide to replace the battery.
A faulty battery does not charge the computer or does not hold a charge for long. If the battery is dead, the computer might not even turn on.
Before starting, make sure all external connections are unplugged and the computer is turned off.
Выберете то, что вам нужно
Set the laptop face down.
Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
Pry open the seam of the back cover using the iFixit Opening Tool.
While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
Once all the corners are slightly lifted, carefully pop off the back cover.
Remove the screws around the perimeter of the battery holding it down with a Phillips #0 screwdriver.
Disconnect the battery cable from the motherboard.
Remove the battery by lifting it out of the laptop case.
7 человек успешно провели ремонт по этому руководству.
6Комментарии к руководству
Great photos and annotations!
One additional tip too for why we should bother pulling the rubber slowly is to also avoid stretching too which will actually change the length of the rubber and have it no longer sit flush on the adhesive like it once did.
Another gotcha too is to note the (+) and (-) terminals on the battery as originally installed. The bad thing about this battery design is that it is symmetric in space which makes it possible to insert it the wrong way! Very dangerous. Take a silver marker and really amplify the terminal pins and note how they are meant to align into the battery slot. Don't get it wrong or you'll short things.
Also worth mentioning since you got the unit open to blow it with compressed air and do any cleaning you can take care of with certain parts easily accessible, eg get that fan cleaned out, etc.
happy fixing folks, good luck!
My front center screw holding the base appears to be a VERY small TORX screw. Any idea what size bit is required?
Mine is too… can’t find anything small enough to take it out
If I recall correctly it’s a T5.
