Введение
The motherboard is the main circuit board found in a laptop. It manages the communication between crucial electronic components that allow your computer to function. This guide will describe how to remove and replace the motherboard for HP Envy x360m6-aq005dx
  1. Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top. Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. Use a Torx T5 screwdriver to remove the six 5.1 mm screws. Use a JIS #1 screwdriver to remove the two 7.2mm screws. Use a JIS #1 screwdriver to remove the two 7.2mm screws.
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. Use a plastic opening tool to pry open the case. Go slowly around the edge.  You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. Use a JIS #1 screwdriver to remove the six 4.7 mm screws. Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  6. Battery might cause a small electric shock.
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
  7. Use the plastic opening tool to disconnect the power cable from the  fan.
    • Use the plastic opening tool to disconnect the power cable from the fan.
  8. Use your fingers to lightly pull the cable and disconnect it from the motherboard. Use your fingers to lightly pull the cable and disconnect it from the motherboard.
    • Use your fingers to lightly pull the cable and disconnect it from the motherboard.
  9. Use a Phillips #0 screwdriver to loosen the four 6.5 mm screws. Do not fully remove the screws, just enough to be unattached from the  motherboard. Use a JIS #1 screwdriver to remove the two 7.7 mm screws.
    • Use a Phillips #0 screwdriver to loosen the four 6.5 mm screws.
    • Do not fully remove the screws, just enough to be unattached from the motherboard.
    • Use a JIS #1 screwdriver to remove the two 7.7 mm screws.
  10. Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions. Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
    • Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
    • Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
    • Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
  11. Using your hand, lift the screen hinge located in the top left corner. This will allow for easier removal of the motherboard.
    • Using your hand, lift the screen hinge located in the top left corner. This will allow for easier removal of the motherboard.
  12. Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward. Use the pointed tweezer  to release the plug-in connectors my gently gripping the plug and pulling backwards. Use the pointed tweezer  to release the plug-in connectors my gently gripping the plug and pulling backwards.
    • Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward.
    • Use the pointed tweezer to release the plug-in connectors my gently gripping the plug and pulling backwards.
  13. Using your hand, lift and pull the motherboard from inside your computer. Using your hand, lift and pull the motherboard from inside your computer. Using your hand, lift and pull the motherboard from inside your computer.
    • Using your hand, lift and pull the motherboard from inside your computer.
Заключение
Bradley Braganza
Участник с: 31.10.2018
196 Репутация
Автор 2 руководств
Команда
IUPUI, Team S1-G1, Harley Fall 2018 Member of IUPUI, Team S1-G1, Harley Fall 2018
IUPUI-HARLEY-F18S1G1
2 членов
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 4
За 30 дней: 6
За всё время: 120
