Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
Use a JIS #1 screwdriver to remove the two 7.2mm screws.
Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
Use tweezers to disconnect the battery from the motherboard.
Use the plastic opening tool to disconnect the power cable from the fan.
Use your fingers to lightly pull the cable and disconnect it from the motherboard.
Use a Phillips #0 screwdriver to loosen the four 6.5 mm screws.
Use a JIS #1 screwdriver to remove the two 7.7 mm screws.
Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
Using your hand, lift the screen hinge located in the top left corner. This will allow for easier removal of the motherboard.
Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward.
Use the pointed tweezer to release the plug-in connectors my gently gripping the plug and pulling backwards.
Using your hand, lift and pull the motherboard from inside your computer.
Еще один человек закончил это руководство.
