Введение
A faulty battery results in no power transfer to the laptop, meaning it wont turn on or charge. This guide will instruct on how to replace the battery to your HP Envy.
Выберете то, что вам нужно
Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
Remove the six 5.2 mm screws using the Torx T5 screwdriver.
Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
Remove the six 4.6mm screws securing the battery using the Phillips #0 screwdriver.
