Введение
The Solid State Drive is responsible for the storing of dynamic random access memory. This guide will instruct on how to replace a Solid State Drive.
Выберете то, что вам нужно
Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
Remove the six 5.2 mm screws using the Torx T5 screwdriver.
Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
Remove the two 4.6 mm screws securing old hard drive/solid-state drive in place using the Phillips #0 screwdriver.
Disconnect the SATA cable connected to the old hard drive/solid-state drive.
Remove the solid state drive.
