Введение
This guide will walk you through the process of detaching the keyboard.
This is the first step to opening the HP Folio Laptop and is necessary to replace any defective hardware.
For safety precautions, it is recommended to wear a anti-static wrist strap or find a way to ground yourself to prevent electrostatic shock to the laptop.
Выберете то, что вам нужно
Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
The top right corner of the keyboard should now be sticking out slightly.
Repeat the same process for the top left corner.
Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
Repeat the same process for the second clamp.
2 участников успешно повторили данное руководство.
2 Комментариев
Awsome Thanks! had my keyboard flooded with some cola :( .. Fixed it !
Turn your Folio 13 upside down.
Looking at the screws on the back, work out which ones go into the keyboard to retain it (it’s only 3!).
You only need to take those screws out.
Use something thin and flat to go around the keyboard, separating it from the case front.
It will lift out easily.
There is no need to remove all 16 screws or take the case front off.
