Введение
The guide will show you step by step how to replace the power button for this device.
Выберете то, что вам нужно
Apply moderate pressure to the tab and slide it to the right.
While the tab is on the right, you should be able to gently slide your battery out of your device.
Turn your laptop over and open it up.
Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
Pull up on the top of your keyboard with medium force. It should start to pop out.
Run your hands underneath the edges of the keyboard until it is free from the device.
Place your thumbs on the two small, white tabs.
Push these tabs forward to release the connection and free the keyboard from the device.
Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
Gently pull the white tab upwards.
With similar force, pull the connection out.
You are now free to pull the power button frame off of your device.
