Введение
This guide will show you how to replace the CD Reader or Optical Drive from your HP G62-234DX.
Before beginning this repair, power off your laptop, unplug from the charger, and remove the battery.
*The CD Reader for our device was broken as there was no cover on the reader.
Выберете то, что вам нужно
While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
Use a spudger to remove hard drive panel and carefully lift it up and out.
Pull the hard drive from the SATA connector to remove the hard drive from the laptop.
Use a Phillips #0 screwdriver to remove the screw that holds the CD reader or optical driver in place.
To remove the CD reader gently push the the back of the CD reader from the hard drive slot and pull it out on the other side.
