Введение
A brief guide on how to remove the hard drive from an HP G62-340.
Выберете то, что вам нужно
Turn off the computer and disconnect the charging cable from the computer.
Turn your laptop over and locate the hard drive module compartment.
Use a screwdriver to loosen the two Phillips PM2.5x6.0 captive screws on the hard drive cover.
Lift the left side of the hard drive cover and remove the cover.
Use a screwdriver to remove the three Phillips PM3.0x4.0 screws on the hard drive.
Disconnect the hard drive cable from the system board and gently remove the hard drive.
Remove the 4 screws from the hard drive bracket and separate it from the hard drive.
2 участников успешно повторили данное руководство.
