HP G71t-400 Hard Drive Replacement
Выберете то, что вам нужно
  1. HP G71t-400 Hard Drive Replacement, Hard Drive: шаг 1, изображение 1 из 3 HP G71t-400 Hard Drive Replacement, Hard Drive: шаг 1, изображение 2 из 3 HP G71t-400 Hard Drive Replacement, Hard Drive: шаг 1, изображение 3 из 3
    • Make sure to completely power off your notebook before continuing. Lay the laptop down so the bottom is facing up.
    • Push the slide button, located below the battery, leftwards to release the battery.
    • Lift and tilt the battery up and away from the notebook to ensure it releases nicely.
    • After the battery is removed hold the power button down for 10-15 seconds to discharge all capacitors
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 Hard Drive Replacement: шаг 2, изображение 1 из 3 HP G71t-400 Hard Drive Replacement: шаг 2, изображение 2 из 3 HP G71t-400 Hard Drive Replacement: шаг 2, изображение 3 из 3
    • Unscrew the 4 circled screws using the PH1 screwdriver to release the cover plate. Remove the screws and set aside.
    • Lift and remove the cover plate to expose the disk drive. Set aside by the screws.
  3. HP G71t-400 Hard Drive Replacement: шаг 3, изображение 1 из 3 HP G71t-400 Hard Drive Replacement: шаг 3, изображение 2 из 3 HP G71t-400 Hard Drive Replacement: шаг 3, изображение 3 из 3
    • Unscrew and remove the 2 circled screws. Set these screws aside, but keep them separate from the cover plate screws.
    • Before touching the disk drive make sure to follow the precautions for handling electrostatic sensitive devices. This will help ensure you do not damage the disk drive and lose your data.
    • After following the precautions, slide the disk drive over so that it disconnects from the disk drive port. An opening tool can be used to help with this but the tool cannot be made of metal or conductive materials
  4. HP G71t-400 Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Carefully lift and remove the disk drive keeping in mind the port.
Заключение
To install replacement and reassemble your device, carefully follow these instructions in reverse order. When doing so, make sure to observe precautions for handling electrostatic sensitive devices.
Nicholas Castro
Участник с: 03/24/19
711 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team S1-G5, Simcock Spring 2019 Участник UMass Dartmouth, Team S1-G5, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G5
2 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 115
