Выберете то, что вам нужно
Turn the device over so that the bottom side is facing up and the battery is facing away from you.
Locate the slider under the right side of the battery.
Using your thumb, slide it all the way to the left until the front of the battery lifts up.
With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
Lift off the Wi-Fi card panel off using the opposite hand.
Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
Using the opposite hand, pull the Wi-Fi card to the left.
2 участников успешно повторили данное руководство.
