HP Laserjet Pro 200 Color MFP Printer Roller Replacement
Выберете то, что вам нужно
  1. HP Laserjet Pro 200 Color MFP Printer Roller Replacement, Printer Roller: шаг 1, изображение 1 из 1
    • Plug in the printer to a wall outlet and place the printer on an accessible surface.
  2. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 2, изображение 1 из 2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 2, изображение 2 из 2
    • In order to rotate the roller to the maintenance position, a secondary menu must be unlocked via the display.
    • To unlock this menu, click on Settings tab (the wrench icon in the top left corner).
    • Once in the Settings menu , quickly click and hold the mid left side of the display (orange square).
    • While continuing to hold the left side, click the bottom right corner of the display (yellow square) and hold it. This should you bring you right back to the startup menu.
    • Once again, click on the Settings tab.
  3. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 3, изображение 1 из 2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 3, изображение 2 из 2
    • Once in the Service menu, click on the "2ndary Service" tab.
    • Scroll down by pressing the down arrow on the bottom right corner of the screen until you find the tab labeled "Pick Roller."
    • Select "Pick Roller."
  4. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 4, изображение 1 из 1
    • Press the "OK" button on the bottom right corner of the screen.
  5. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 5, изображение 1 из 1
    • Unplug the printer from the side by pulling on the base of the cord.
    • Unplug the printer rather than manually turning it off using the power button in order for the roller to stay in maintenance position.
  6. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 6, изображение 1 из 1
    • Remove the paper tray by pulling it out from the bottom completely.
  7. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 7, изображение 1 из 2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 7, изображение 2 из 2
    • Rotate the printer as shown so that the front is facing your left.
    • Flip the printer so that its right side is facing down, and you are facing the bottom.
  8. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 8, изображение 1 из 1
    • Use a metal spudger or a small flathead screwdriver to lift the tabs on each side of the roller.
  9. HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 9, изображение 1 из 2 HP Laserjet Pro 200 Color MFP Printer Roller Replacement: шаг 9, изображение 2 из 2
    • Pull out and remove the roller.
Заключение
2 участников успешно повторили данное руководство.
Kendall Gentzen
Участник с: 04/18/19
981 Репутация
Автор 5 руководств
Команда
Cal Poly, Team S9-G14, Maness Spring 2019 Участник Cal Poly, Team S9-G14, Maness Spring 2019
CPSU-MANESS-S19S9G14
4 членов
Автор 11 руководств
5 Комментариев
I can not get the 2ndary Service menu to appear. I have followed these instructions very carefully. Is there another way to access this mennu?
James Herzog - Ответить
@James Herzog. I had to try at least ten times before I got that key sequence working. Try pushing bit different spots and bit different speeds etc.
Rixa - Ответить
Lord God. This worked just as you instructed. I'm still ready to throw the printer to the curb, but this did work!!
Karen-Glenn Richardson - Ответить
Thank you so much, I reversed the rubber band in the roller and now it worked like new
Ali AlKhawaher - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 38
За последние 30 дней: 135
За всё время: 8,947
