Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The optical drive (also known the CD drive) is one of the most frequently used parts of the HP Media Center 876x. As a result, damages are common and often replacement is necessary.
Выберете то, что вам нужно
Place the tower on its side.
Slide the side panel horizontally to detach, and pull upward to remove.
Orient the tower vertically.
Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
Slide the side panel out of its notches, and pull it gently off of the tower.
Gently move the tower so that it is in the horizontal orientation.
Press down the black tabs (proximal to you) that fasten the front panel to the tower.
Press down on the distal, black tabs (symmetric with respect to the previous tabs).
Pull front panel forward slightly.
The front panel will come off in a hinge-like fashion, exposing the drives underneath.
Identify the optical drive.
Pull the molex connectors out of the posterior end of the optical drive.
Using the #0 Phillips head screwdriver, unscrew the two (5 mm) screws that fasten the optical drive into its port.
Gently pull the optical drive through the frontal cavity.
2 участников успешно повторили данное руководство.
