Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The HP Media Center 876x is capable of receiving television service through its TV tuner card. If you are unable to receive proper service, the TV tuner card may require replacement.
Выберете то, что вам нужно
Place the tower on its side.
Slide the side panel horizontally to detach, and pull upward to remove.
Identify the TV tuner card (distal from the cooling fan, in the lower-left corner of the tower).
Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the TV tuner card into its slot.
Еще один человек закончил это руководство.
