Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Internal Prerequisite.
Выберете то, что вам нужно
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
