HP Mini 110-3131dx Keyboard Bezel Replacement
Выберете то, что вам нужно
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Keyboard Bezel Replacement, Back Cover: шаг 2, изображение 1 из 2 HP Mini 110-3131dx Keyboard Bezel Replacement, Back Cover: шаг 2, изображение 2 из 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Keyboard Bezel Replacement, Hard Drive: шаг 3, изображение 1 из 1
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 4, изображение 1 из 2 HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 4, изображение 2 из 2
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
  4. HP Mini 110-3131dx Keyboard Bezel Replacement, Keyboard: шаг 5, изображение 1 из 1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  5. HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 6, изображение 1 из 3 HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 6, изображение 2 из 3 HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 6, изображение 3 из 3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  6. HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 7, изображение 1 из 1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
  7. HP Mini 110-3131dx Keyboard Bezel Replacement, Keyboard Bezel: шаг 8, изображение 1 из 2 HP Mini 110-3131dx Keyboard Bezel Replacement, Keyboard Bezel: шаг 8, изображение 2 из 2
    • Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
    • Be sure to keep track of which screws go where as they are not all the same size.
    • Flip the laptop over and remove the six black screws.
  8. HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 9, изображение 1 из 2 HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 9, изображение 2 из 2
    • Using your fingernail or the iFixit opening tool, flip the black tab up to release the ribbon cable that connects the touchpad and motherboard.
    • Disconnect the red and black wires from the motherboard on the left-hand side of the bezel using your fingernail or iFixit opening tool.
  9. HP Mini 110-3131dx Keyboard Bezel Replacement: шаг 10, изображение 1 из 1
    • Lift the keyboard bezel from the back end and slide the iFixit opening tool around the perimeter of the bezel until it is fully released.
Заключение
Еще один человек закончил это руководство.
aarondcollege
Участник с: 10/06/16
1 297 Репутация
Автор 10 руководств
Команда
USF Tampa, Team 2-4, Cagle Fall 2016 Участник USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 10
За всё время: 420
