HP Mini 110-3131dx Keyboard Replacement
Выберете то, что вам нужно
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Keyboard Replacement, Back Cover: шаг 2, изображение 1 из 2 HP Mini 110-3131dx Keyboard Replacement, Back Cover: шаг 2, изображение 2 из 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Keyboard Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Keyboard Replacement: шаг 4, изображение 1 из 3 HP Mini 110-3131dx Keyboard Replacement: шаг 4, изображение 2 из 3 HP Mini 110-3131dx Keyboard Replacement: шаг 4, изображение 3 из 3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  4. HP Mini 110-3131dx Keyboard Replacement: шаг 5, изображение 1 из 1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
Заключение
To install a different keyboard, follow these instructions in reverse order.
2 участников успешно повторили данное руководство.
aarondcollege
Участник с: 10/06/16
1 297 Репутация
Автор 10 руководств
Команда
USF Tampa, Team 2-4, Cagle Fall 2016 Участник USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 2,130
