Введение
This is a step by step guide to help you replace the memory card for the HP Mini 110-3131dx in order to increase the laptop's performance.
Выберете то, что вам нужно
Power off the laptop before trying to remove the battery.
Turn the laptop upside down, and locate the sliding tabs on the battery.
Slide both tabs in an inward direction, then slide the battery away from the laptop.
To remove the bottom cover pull the orange tab to the right until it clicks.
Carefully disconnect the clips as you lift the bottom cover.
Find the two silver screws that hold the memory card cover.
Take a PH1 screwdriver and unscrew the two screws.
Remove the metal cover
Pull the two white tabs located on either side of the memory card away from each other until the card pops up
Remove the card
To install the new memory card, follow these instructions in reverse order.
Еще один человек закончил это руководство.
