Введение
If your screen is damaged, flicking, or cracked, use this guide to replace the screen.
Выберете то, что вам нужно
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
Lift the hard drive cage by pulling the tape upward.
Start by pulling the tape from the side with the keyboard symbol.
Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
Lift the two black holders upward located next to the socket for the keyboard close to the tracked pad.
Close the laptop by bringing the screen down.
Flip the laptop over to the other side.
Remove the 6 5.0 mm screws holding the back plate together using a Phillips #1 screw driver.
Remove the 2 3.0 mm screw head holding the plastic piece in place using a Phillips #1 screw driver.
Located on the left and right side where the battery was removed.
Pull the black plastic pieces that the screws was holding inward.
The pieces are located on the left and right corners connecting the bottom and top of the HP Mini.
Using the plastic prying tool, pry the front plate of the bottom part of your HP Mini.
Remove the display cable from the motherboard located on the top left corner under where the keyboard was by pulling on the black tab.
Move the cable.
Remove the webcam cables from the motherboard.
Located on the back side of the laptop in the bottom left corner.
Flip over the computer, and open the laptop.
Lift up the front plate on the top right corner.
Remove the 2 3.0 mm screws on both sides of the bottom of the display using a Phillips #1 screwdriver.
Remove the black plastic piece that the screw was holding on both sides.
This will reveal another screw.
Pry the front plate using the plastic opening tool by pushing along the border of the front and back plate.
Make sure to pry from the sides, top and bottom as the corners will come undone themselves.
Remove the 4 4.0 mm screws holding the screen in place using a Phillips #1 screw driver.
Under the screen, peel off the tape near the cable completely, so you can see the socket for the cable.
Один комментарий
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
