Пропущенные шаги
Ой! В настоящее время в этом руководстве отсутствует один или несколько важных шагов.
Ненаглядные фото
Будьте героем экшена! Изображения в этой инструкции должны более наглядно демонстрировать, как нужно выполнять то или иное действие.
Нужны более качественные фото
Более качественные фотографии улучшат это руководство. Помогайте, делая снимки, редактируя или загружая новые!
Введение
Перейти к шагу 1 ↓This guide will teach you how to perform a fan replacement on the HP Mini 210.
Выберете то, что Вам нужно
Инструменты
Spudger4.9
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
Once you have removed the screws, flip the netbook over so that the keyboard is now facing upwards. Open the screen as far back as the netbook allows.
Using a prying tool, lift upwards and remove the plastic casing that covers the spaces around the keys of the keyboard.
Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
Use the spudger to peel the front black plastic plate from the rest of the case, starting at a corner and working your way around the entire case.
Locate the cable that connects the trackpad to the motherboard and carefully remove it.
Flip over the motherboard to get to the fan.
Carefully remove the cable that is attaches the fan to the motherboard.
Remove the screws that hold in the fan.
The fan is now able to be completely removed.
3 человек успешно провели ремонт по этому руководству.
