Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
Once you have removed the screws, flip the netbook over so that the keyboard is now facing upwards. Open the screen as far back as the netbook allows.
Using a prying tool, lift upwards and remove the plastic casing that covers the spaces around the keys of the keyboard.
Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
Peel off black plastic front plate using spudger, working from one side and slowly separating the plate from the rest of the case.
Carefully remove the cable that connects the trackpad to the motherboard.
Remove screws securing the metal trackpad holder.
Remove metal track pad holder from front plate.
Remove screw holding the capacitor in place.
Lift up but do not remove capacitor.
Locate the cable connected to the trackpad.
Carefully lift up the metal latch holding on the trackpad cable.
Lift trackpad cable away from the trackpad.
Еще один человек закончил это руководство.
