Введение
Use this guide to remove the battery and the back cover of your laptop in order to repair or install new parts.
  1. Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over, so that the underside is up and the silver battery bay is facing towards you.
  2. Locate the battery locking latch on the bottom right corner and slide it inward to unlock the battery. Locate the battery release latch on the bottom left and slide it inward. Pull the battery towards you to remove it from the laptop.
    • Locate the battery locking latch on the bottom right corner and slide it inward to unlock the battery.
    • Locate the battery release latch on the bottom left and slide it inward.
    • Pull the battery towards you to remove it from the laptop.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Locate the service access cover release lever and slide it to the right. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover from the laptop. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover from the laptop.
    • Locate the service access cover release lever and slide it to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover from the laptop.
  5. If you are performing any installations after the battery, orient the computer so that the underside is up, and the battery port is facing away from you.
    • If you are performing any installations after the battery, orient the computer so that the underside is up, and the battery port is facing away from you.
Заключение
Sean Kuster
Участник с: 05.10.2012
79 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 3-23, Amido Fall 2012 Member of Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 9
За всё время: 1,237
