Введение
Use this guide to remove the battery and the back cover of your HP Mini 210-2070NR laptop in order to repair or install new parts.
Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
Slide the battery release latch inwards.
Pull the battery towards you to remove it.
Slide the service access cover release lever to the right.
While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
2 человек успешно провели ремонт по этому руководству.
