Введение
The Wi-Fi Card is also called a WLAN Module, and is what connects you to the internet without needing to be attached to a cord.
Выберете то, что вам нужно
Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
Slide the battery release latch inwards.
Pull the battery towards you to remove it.
Slide the service access cover release lever to the right.
While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
Locate the Wi-Fi Card (WLAN Module), near the computer's bottom left corner.
Disconnect the two cables from the Wi-Fi card by gently lifting them away from the card.
Remove the two 2.0 x 3.0 screws securing the Wi-Fi card using a Phillips #00 screwdriver
