Введение
If you are having problems with internet connection, you may want to replace your wireless network card on your HP Mini 311.
Выберете то, что вам нужно
Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
2 участников успешно повторили данное руководство.
