HP Notebook 15-ba018ds Wifi Chip Replacement
Выберете то, что вам нужно
  1. HP Notebook 15-ba018ds Wifi Chip Replacement, Battery: шаг 1, изображение 1 из 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 2, изображение 1 из 3 HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 2, изображение 2 из 3 HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 2, изображение 3 из 3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: шаг 3, изображение 1 из 2 HP Notebook 15-ba018ds Wifi Chip Replacement, Wifi Chip: шаг 3, изображение 2 из 2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
  4. HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 4, изображение 1 из 1
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 5, изображение 1 из 2 HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 5, изображение 2 из 2
    • Use a Phillips screwdriver to remove the screw holding down the wifi chip.
  6. HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 6, изображение 1 из 2 HP Notebook 15-ba018ds Wifi Chip Replacement: шаг 6, изображение 2 из 2
    • Remove the two wires connected to the wifi chip.
    • The wires are labeled 1 and 2. This is important to know when reconnecting the wires to the wifi chip.
    • Gently pull the wifi chip out and replace with a new wifi chip.
Заключение
Еще один человек закончил это руководство.
Terrell Bradford
Участник с: 09/18/18
443 Репутация
Автор 3 руководств
Команду
University of North Texas, Team S3-G2, Raign Fall 2018 Участник University of North Texas, Team S3-G2, Raign Fall 2018
UNT-RAIGN-F18S3G2
4 членов
Автор 4 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 35
За всё время: 1,101
